Sound? I've lost my sound! Help! Please
Discussion in 'iPad Help' started by Hdchiky, Sep 11, 2011.
  1. Hdchiky
    Hdchiky
    Jul 30, 2010
    323
    Not sure what is going on with my iPad. I can play music from the iPod app - hear sounds from YouTube videos. I cannot hear any sounds from games like Angry Birds or Trucks & Skulls or my keyboard clicks (which are all set to ON for sound). Any suggestions for somewhere I can look? It must be something dumb or simple I have done.... Thanks for any info!
    Chiky
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    OK - I'm sure you checked you've not accidentally activated Mute - since some games mute the audio when the Mute function is activated. You're an experienced user so you'll know the Mute function is either a hard switch or soft switch. Given all those check out, how about a reboot?
    Is your iPad in a dock? Does the problem persist if you connect a headset?
  3. Hdchiky
    Hdchiky
    Jul 30, 2010
    323
    Thanks for replying Tim! No, the mute button was not the issue. Yes, I had turned it off/ on, but.... You were right about the headphone - when they are connected I hear the Angry Birds! What have I done?
    Chiky
  4. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    OK - do you have a version of iOS which has a re-assignable Mute function - i.e. to the soft control? OK - just wanted to be sure, don't get mad....:(
    I would then try a power-off, power-on reset - it really does cure so many problems.
    Beyond that, I'm starting to run out of ideas...
  5. Hdchiky
    Hdchiky
    Jul 30, 2010
    323
    Hey... I would never get mad!! Not that kind of girl!!! The iPad shows the version as 4.3.5 (8L1) a does that tell you anything? Thanks for your help!
  6. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,236
    122
    OK - so you've got a version of iOS that has a re-assignable Mute switch. Double press the Home button to open the multi-task bar, flick the screen to the right and see what the button on the very left of the screen in the multi-task bar is assigned to. It's possible it's been set to the Mute switch here (because, with this version of the operating system you can change the allocation of Mute from the hard switch next to the volume control to the soft switch in the multi-task bar. That change can be made in the 'Settings' menu and some Members have found they've 'accidentally' switched the function from hard to soft switch. Hence the hard switch would then control the orientation lock instead.
    The mute function leaves the headphone connection unaffected so that's why, even with Mute set (if, indeed, it is) you can still hear the games via the headphones.
    OK - if I've made a big mistake here and it's not the Mute function (a) forgive me and (b) we'll try some other things....thanks for your patience...
  7. Hdchiky
    Hdchiky
    Jul 30, 2010
    323
    Tim! You need your superman pic back out there!!!! For sure YOU are my hero! That WAS it! All sounds seem to be back! That was the one place I never looked (double clicking the home button...nothing showed in settings). Thank you so very much. Can't stand for anything to be wrong with my iPad!
    Chiky
    I love this forum!
  8. SweetPoison
    SweetPoison
    iPad Legend
    Jun 20, 2010
    14,913
    133
    Tim is our hero to be sure.
    [​IMG]
  9. Montanamuse
    Montanamuse
    Sep 12, 2011
    Thanks so much, Tim! I had the same problem today after doing a reset and was about to go mad trying to figure out what went wrong. You're my hero of the day for sure! :)
  10. Parampal
    Parampal
    Mar 13, 2012
    Thanks, tim that solution worked for me as well.
    Sent from my iPad2 using the iPF App
cannot hear sound on ipad
cannot hear sound on my ipad
cant hear video on ipad
cant hear youtube on ipad
i cannot get sound on my ipad
i cannot hear music on my ipad
i cant get sound on my ipad
i cant hear anything on my ipad
why cant i hear anything on my ipad
why cant i hear sound on my ipad
