Sound issues
Discussion in 'iPad Help' started by kaylynelle, Jul 13, 2011.
  1. kaylynelle
    kaylynelle
    Jul 13, 2011
    My iPad crashed last night so I needed to turn it off to fix the issue. When I turned it back on the headphones were plugged in. Now, the sound will only work with headphones. I have tried turning the iPad off and on again without the headphones plugged in but it hasn't helped.
    Any ideas on how to fix this, please?
    Kay
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,225
    I read somewhere here on this forum that the iPad tries to "protect" you when using earphones. The sound levels/volumes are different for the iPad and the earphones and the iPad will adjust one or the other. Or, something like that...
    The thing I remember is this attempt to fix sound issues: Disconnect the earphones and check to make sure the sound on the iPad is not turned all the way down? It might just have been muted (as a "safety" feature)...
    If not, I don't know what it could be. Sorry.
  3. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,230
    7,475
    Try a reset.
how to fix my ipad 3 sounds
how to fix the sound on a ipad
how to turn the sound back on an ipad
ipad apple sound issues
ipad sound issue
sound issues with ipad
