Sound issue, keyboard clicks not working
Discussion in 'iPad 2 Forum' started by Rilakuma85, Mar 6, 2013.
  1. Rilakuma85
    Rilakuma85
    Mar 6, 2013
    Hi
    This morning I just started using my ipad and the keyboard clicks arent working.. Ive checked both the keyboard click option in settings and the mute sounds thing on the taskbar/ switch on the side.
    It was fine yesterday and i dont think i changed anything.
    Thanks for any input!
  2. The OB
    The OB
    Staff Member
    Aug 10, 2012
    4,616
    1,642
    Welcome to the forum, Rilakuma! Apple recommend that it is a good thing to periodically reset your iPad, which clears out RAM and cache memory and thereby have your iPad running more sweetly. Do this:
    Simultaneously hold down the OnOff and Home buttons until the screen blacks out. Don't let go but keep holding until the white Apple logo appears. (Ignore any slide-On button that may appear) Then let go both buttons and wait until your wallpaper appears and slide to On. This procedure does no harm to any app or settings. Hope that helped.
    Regards Andrew
  3. Rilakuma85
    Rilakuma85
    Mar 6, 2013
    Thanks for the welcome Andrew. Seems like a good place to be ;)
    Excellent, it is working as normal now! Good to know :) thankyou
  4. The OB
    The OB
    Staff Member
    Aug 10, 2012
    4,616
    1,642
    No worries. Enjoy your iPad!
ipad keyboard clicks not working
ipad keyboard clicks stopped
ipad keyboard not clicking
ipad keyboard sound not working
ipad keyboard sounds not working
keyboard clicks not working ipad
keyboard clicks not working on ipad
keyboard clicks on ipad not working
no clicks on ipad
