Sound effects icon
Discussion in 'New Member Introductions - Site Assistance' started by larnett, Jul 1, 2013.
  1. larnett
    larnett
    Jul 1, 2013
    Does anyone know how to get the sound effects icon off my screen. I have tried refreshing, rebooting, and turning it off. I have taken my iPad out of its case, still no luck. I can' t get it off. Someone please help me!
  2. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    18,991
    11,601
    Hi, larnett! Welcome to iPF!
    In most cases rebooting and restarting should help. If it didn't work at first, try a second time.
    You could also try to turn the volume up and down again. Make sure it's reacting as it should.
    If you've set your side switch to Mute, turn this one on and off a few times.
    #2 J. A., Jul 2, 2013
  3. Richard Brown
    Richard Brown
    iPad Expert
    May 1, 2011
    7,531
    450
    Hello Larnett
    Welcome to the forums. You will find that we are a very helpful bunch. You are joining a great worldwide community.
    Now, I suggest that one of the first things you do is to read the forum rules etc. Links to useful sections follow :-
    The forum rules may be found here.
    We have our own App which is easy to navigate.
    The iPad manual is here.
    Try these informative threads from which you will learn many tips and shortcuts for the IPad.
    Most importantly, enjoy your time with us on the forums.
    Then I recommend you use the forum search function to find threads to visit, read and ask questions there. This way, you should get a good response. :)
    If you have any questions or comments please don't be afraid to post.
    Thank you, and welcome aboard.
  4. Roy Rob
    Roy Rob
    iPad Addict
    Nov 21, 2012
    1,148
    144
    Hi larnett...could you post a screen capture so we can see what your concern is? Is the volume button stuck?
  5. larnett
    larnett
    Jul 1, 2013
    Here is the screen shot. Please help!
  6. Roy Rob
    Roy Rob
    iPad Addict
    Nov 21, 2012
    1,148
    144
    Are you sure the volume button is not stuck? Fiddle around with it and let us know. What iPad do you have I, II, III or IV? Do you have full volume in apps ?, can you turn down the volume using the toggle button (not the slider)?
  7. larnett
    larnett
    Jul 1, 2013
    So I have discovered that when I took the case off there is a slight indent where the sound buttons are. How do I try to fix this without damaging the iPad?
  8. Roy Rob
    Roy Rob
    iPad Addict
    Nov 21, 2012
    1,148
    144
    If it was me larnett I would just make sure that the toggle switch is in the "neutral" position (not stuck up or down) and use the slider to adjust your volume from now on.
how do i turn sounds effects off on ipad
how to turn off sound effects button
how to turn off sound effects on ipad
how to turn on sound effects on ipad
how to turn up sound effects on ipad
ipad sound effects icon
sound effect icon on ipad
sound effects icon on ipad
turn off sound effects icon on ipad
