Sound alerts
Flip1
Ca
Hi I am a new I pad owner and would like to know if you can have sound alerts for new e mail ect when the pad is turned off or if the only way alerts work is when you turn pad on. Thenks
Mickey330
Western NY state (USA)
If your iPad is fully turned off (as in, you did the "slide to power off" maneuver), then you will not receive notifications until you turn the iPad back on.
However, if you put the iPad to sleep, by press the button opposite the Home button, then it will continue to check for or receive notifications.
Hope this helps.
F
Flip1
Ca
Many thanks I will give it a try didn't know about sleep mode
leelai
Brisbane, Australia
Hi and welcome to the Forum!
iPad 2 3G 64gb
