Review of RavPower Icona power bank
Discussion in 'iPad Accessories for iPAD 1, 2 and 3' started by donka, Sep 9, 2013.
  1. donka
    donka
    Sep 21, 2010
    864
    63
    The Icona is a rechargeable 10,000mAh Li-Polymer battery unit that can then be used to charge a slave device connected to it via USB. Included in the package is the RP-PB04 External Battery, coiled USB cable, 4 cable adapters, user manual, and travel pouch. The 4 adapters convert the supplied cable to Mini USB, Micro USB, Nokia and iPod 30 pin connections. If you prefer, you can use the USB cable that comes bundled your device instead.
    The Icona is about the size of a portable 2.5" USB drive and has a sleek and stylish finish. It feels sturdy in the hand, in part due to the weight of the internal battery and also thanks to the good construction on offer. The unit does have a smooth all over finish though so be wary of placing this somewhere it may slide.
    It features a power button and four LEDs on the top to indicate remaining power. On the end it has two full sized USB ports as well as a central micro USB port for recharging. It takes around 13 hours to fully recharge the unit from empty. There is no supplied charger but the included cable or indeed any other micro USB cable can be used in connection with any USB source.
    From a full charge, 10,000 mAh of portable power is on offer. To put this in an IOS perspective, an iPhone 5 rated @ 1,440 mAh could be fully charged almost 7 times. An iPad mini @ 4,490 mAh could be charged twice while a full sized iPad 4 with retina @ 11,560 mAh could be charged up to around 85%. While it is unfortunate we can't squeeze out a full charge of the biggest iPad, it still receives a healthy shot in the arm and should be more than enough to keep you going in an emergency or for an extended time. Speaking of the retina iPad, this power bank features both a 2A & 1A USB port, the former of which is perfect for the more power hungry iPad; you can continue to work on the iPad while it is charging. Two devices can also be charged simultaneously for a combined output of 3A which makes this a flexible performer. One thing I did note during my testing was that regardless of what device you are charging or even if you are recharging the Icona, it remained cool at all times with no sign of heating up. This is a welcome surprise when it comes to portable devices and batteries.
    For me, travelling with my usual compliment of gadgets makes a product like a power bank a sensible purchase. All my portable gadgets from phones, tablets, music player, ebook reader and camera can be charged via USB and having the ability to do this when away from a fixed power source gives real peace of mind. The RavPower Icona delivers a high power capacity and flexibility of dual charging in a portable and well priced package. This is available for around £25 @ RAVPower® Icona 10000mAh Li-Polymer Power Bank External: Amazon.co.uk: Electronics
    Video review @
    #1 donka, Sep 9, 2013
  2. CASEYL
    CASEYL
    Sep 26, 2013
    I have one of the RAVPower 14000mAh. It works great with everything I've tried.
    I picked it up at Amazon.com. For $38 when it's on promotion.
battery
can i use apple ipad charger to charge ravpower 13000mah power bank
power bank
ravpower icona review
ravpowwer 1675mah
