Reserve/External Battery for iPad
Discussion in 'iPad General Discussions' started by RAC, Jan 28, 2011.
  1. RAC
    RAC
    Jun 6, 2010
    615
    7
    Any recommendations?
    Two that I know of:-
    ZaggSparq - $100 but closer to $150 by the time it is shipped to Australia. 6,000 mAh, 2 amps output, the same as the iPad charger. Requires US/AU adaptor, one more thing to forget to take with you.
    Energizer XP8000 - Available in Australia for $180. 8,000 mAh but only 1 amp output just enough to keep the iPad going (I think) and maybe slowly recharge it.
    I want this mainly so that I can continue to use the iPad when the battery gets low.
    Any comments and alternative suggestions welcome.
    PS no need to convert USD to AUD at the moment:).
  2. DM51
    DM51
    Aug 19, 2010
    669
  3. RAC
    RAC
    Jun 6, 2010
    615
    7
  4. RAC
    RAC
    Jun 6, 2010
    615
    7
    I eventually purchased the Morphie Powerstation. It is supplying power to my iPad right now and seems to work well.
    It's capacity is 3,600 mAh which think is less than a full iPad recharge, which I believe is about 5,000 mAh (based on the quoted 25 Watt Hours and assuming that this is at 5 Volts).
    It does fill my need to keep the iPad going until the next recharge when the internal battery gets below 10%. Most importantly it has a maximum output of 2 Amps.
howcan u resetve ipad battery
ipad battery reserve
ipad charger reserve battery
ipad power reserve
ipad supplimental battery
power reserve for ipad
reserve battery for ipad
reserve battery power for ipad
reserve battery power ipad
reserve power for ipad
