Remote desk top control
Mustang77
Chicago,il
Does anyone have one they can recamend? I seen some and lots dont work with win7home eddition. Seems like they need extra software to work. Any input is welcome
Renzo
I'll help you use itap rdp
If you use search function you will see multiple threads about same subject
Sent from my iPad2 using Tapatalk
netsecpro
Check out Jumpdesktop. I use it on a daily basis. I like it because if you install the software on your computer, you can either use the RDP or VNC protocols, and here is no neednto have a VPN connection to your network. If youbonly want to use it without installing the client software on your computer, then you will need a VPN connection.
M
Mustang77
Chicago,il
Thank u everyone . I have been looking and seems like i will pick it up soon .
M
Mustang77
Chicago,il
I bought the jump desktop and love it, is it possibl to directly hook to a laptops wifi with my ipad with out useing gmail . Just wondering , cant seem to do it
