Problems with wifi connection
Discussion in 'iPad 2 Forum' started by hinke00, Nov 1, 2011.
  1. hinke00
    hinke00
    Oct 26, 2011
    23
    Sometimes i can use facebook and safari, with safari sometimes i can open pages , but not everyone i want. It says server not found or connection problem, adn at the same time im able to open different pages. Appstore rarely works. This forum app said connection problem two minutes ago, now i can connect. There wasnt any change in neetwork and i dont know why it works now and why it didnt work two minutes ago. An other case: the mailing application downloaded my emails, but i couldnt open a link in the email with safari. And also sometimes i can send letters, sometimes i cant. When i cant open something, i try it again and again hoping it will work, but it doesnt work most of the time. The pad says im connected. The wifi network is ran by my laptop with a program. But four days ago it worked perfectly this way. I cant have low signal problems, because the laptop is here beside me. Any ideas how to fix this?
  2. w1ngman
    w1ngman
    Oct 25, 2010
    42
    My first suggestion might be to get your iPad to *another* wifi point (ex. public library, restaurant w/ free wifi, etc) and see if your iPad continues to exhibit these symptoms. If it does not, then there is something problematic with that software on your laptop. If the iPad does exhibit these same symptoms at other wifi points, then you should visit an Apple store for Genius assistance.
    - Dave
apple safari server not found
i have wifi conection but appstore dont open to me
ipad says server not found
ipad server not found
safari cannot open server not found
server not found ipad
server not found on ipad
server notfound on ipad
xart server not found on ipad
