Problems with Skype
Discussion in 'iPad Help' started by Liv Ellen, Jun 1, 2011.
  1. Liv Ellen
    Liv Ellen
    Jun 1, 2011
    I have been using Skype on my iPad 1 since I bought it a year ago. Now my contacts cannot hear me. Running the test call, this confirms I can hear the test message, but not my own response. The lady suggsted I adjust my sound setting. How? I have checked the volume but can see no other way of checking what is wrong. Can the microphone have packed up?
    Liv Ellen
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
  3. Liv Ellen
    Liv Ellen
    Jun 1, 2011
    Thanks, Tim. The second suggestion worked!
    Liv Ellen
  4. makingitabc
    makingitabc
    Apr 9, 2013
    Thanks Tim your fix solved the Skype problem on our Ipad3. Lanny Houston
blank screen when use skype on ipad
if your skype screen is black on ipad
ipad skype black screen
ipad skype problems
problems using skype on i-pad
skype black screen ipdad
skype ipad black screen
skype on ipad problems
skype screen black on ipad
skype screen black video on ipad
