Safari has a problem for a while, which it would lag while loading a page, then go to the home page (the one where all you apps are). It usually was just a minor annoyance (as the pages would have to reload if you entered them, and also you have to constantly click safari). But just now, when I got kicked out, all my pages were gone. Then there was no history recorded even though I had some of the pages for over an hour. Can someone enlighten me whats going on? And also on the problem of safari kicking me out? Its very exasperating.
