Problem with upgrading OS
Discussion in 'iPad Help' started by paddington_nk, Mar 27, 2011.
  1. paddington_nk
    paddington_nk
    Mar 27, 2011
    HI
    Sorry if this has been covered anywhere else... i have been trying for the last 10 hours to upgrade the OS from 3.2.something to 4.3 (i think it said)...
    I went out this afternoon and left it running, and when i got back it appeared to have frozen, so i held down the home and on/off button and then replugged it back into Itunes, and its asking for a restore, however it now seems to be frozen, with the progress bar having moved about a centimetre across, and no further in the last 30 mins.... any help anyone can give will be greatly appreciated!
    thanks
  2. Mountaingamer
    Mountaingamer
    Mar 26, 2011
    81
    If this were me I would reboot the computer, and be sure I am using the usb cable that came with the Ipad, not the ipod or iphone usb cable.
  3. paddington_nk
    paddington_nk
    Mar 27, 2011
    thanks, i have now uninstalled itunes, reinstalled in, am now using the correct cable (didnt realise using the ipod cable would make a difference), plugged ipad (16gb wifi) in again, it looked like it was doing something (verfied ipad, extracted files, started restore) however it now just says restoring ipad software (in itunes) and i have a apple and empty white bar on the device itself?!
    help!!! :(
  4. Mountaingamer
    Mountaingamer
    Mar 26, 2011
    81
    Did it finish?
  5. tzimisce
    tzimisce
    iPad Addict
    Sep 23, 2010
    1,078
    You should see the Apple and the white progress bar in the last few steps of the OS install: but can you actually see progress in the bar itself?
  6. integrateis
    integrateis
    Mar 28, 2011
    7
    It will be best if we could try to upgrade to the latest OS version.
ipad operating system update problem
ipad problem when upgrade version
problem upgrading ipad operating system
