Problem with Settings
kathylala
Can anyone help with a problem I have?
I can't open Mail, Contacts, Calendar on my IPad
Still fairly new to my iPad so apologies if this is something basic!
leelai
Brisbane, Australia
Hi and welcome to the Forum!
With regards to your question when an app behaves strangely it is best to close it completely and then relaunch it. To do this do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, if not a restart is in order.
When an App or your iPad begin to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
K
kathylala
Thanks very much for the advice, but the problem is in my 'Settings' App on the Main Desktop.
When I go into 'Settings' and click on "Mail, Contacts,Calendar", it throws me out and goes back to the Main Desktop.
Does that make sense?
leelai
Brisbane, Australia
It seems the app is crashing, did you follow the steps I gave you above and it's still not working? I don't know what else to advise, someone else may chime in here who can help you.
K
kathylala
Yes I did as you said but it's still taking me back to the main desktop.
I can access all the other Settings but when I try and access the Mail, Contacts, Calendar Settings it throws me out every time.
I can access my e mails through the Mail App, but can't access the Settings using the Settings App
Thanks for your help though, much appreciated, will keep working at it.
LoneStar1948
Glasgow, Scotland
I have exactly the same problem, and it also affects Contacts - if I try to open Contacts it also throws me back to the Home screen. I have rebooted the IPad and I've also done a complete reload of IOS5 via the Restore function in iTunes, all with no resolution of the problem. There is a thread on this in the Apple Support Communities forum where a few other people have the same thing.
