Problem with my iPad michrophone .
Discussion in 'iPad Help' started by joanne kagioglou, Jan 12, 2013.
  1. joanne kagioglou
    joanne kagioglou
    Jan 12, 2013
    Hi, can anyone help me! My mic is not working on my iPad. I cannot record sound using the cam or Skype.
  2. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,831
    1,306
    Hi and welcome to the Forum!
    Check to make sure your mic doesn't have any debris in it. In case you don't know the mic is in the centre on the top edge of your iPad. But don't go sticking anything into it, I have heard a quick vacuum has helped others with this problem.
    In the meantime I've moved your thread to our Help Section where you will receive a better response.
    Tutorial on creating posts on the Forum
    http://www.ipadforums.net/new-member...reads-how.html
    http://www.ipadforums.net/ipad-os/49...ps-tricks.html
    http://www.ipadforums.net/ipad-help/...-new-ipad.html
    http://www.ipadforums.net/forum-rule...html#post14697
  3. joanne kagioglou
    joanne kagioglou
    Jan 12, 2013
    Thank you for your support; I tried everything and still get no sound when I record. It looks like I will have to take it to an apple center and get them to sort it out.
  4. Roy Rob
    Roy Rob
    iPad Addict
    Nov 21, 2012
    1,148
    143
    I can confirm vacuuming the mic worked for me. I hadn't used the mic on the iPad 2 for quite a few months, then noticed when trying a VOIP telephone call, the other person could not hear me at all. Vacuuming the mic (tiny hole on the centre, top edge of the iPad) restored the mic to normal.
    A tip, when vacuuming, get as much suction as you can by using the crevice tool attachhment on the vaccum and using your fingers to close off as much of the tools opening as possible to maximize the suction. I noticed it took about 30 seconds of vaccumming before the mic worked again. 5-10 seconds wasn't enough. So if it doesn't work at first, keep vacuuming. Hope this helps. ;)
  5. joanne kagioglou
    joanne kagioglou
    Jan 12, 2013
    Thank you Roy, I will try it with the vacuum but It will have to wait till I return back home from my holiday to try it. I will let you know how it went.
how to vaccum the mic of ipad
ipad can't record sound
ipad michrophone doesnt work
mic wont work on ipad 2
my ipad the sound cannot record
