Problem with 3G
tanky
Hi, I just joint this forum and I am having problem in my iPad 2. I have a 3G access but every now and then I need to switch off and on the flight mode to get connected to 3G. My vendor told me to reset network but it still doesn't work. I even get the SIM card replaced but still the problem still there. Can anyone help?
Tim SPRACKLEN
I've moved this to a new thread; it's not a good idea to 'hijack' another thread as it leads to confusion. But, no problem.
T
tanky
Noted with thanks, Tim
Tim SPRACKLEN
