Problem when starting Cydia...!?
Discussion in 'iPad 2 Forum' started by AAA, Feb 22, 2013.
  1. AAA
    AAA
    Nov 18, 2011
    40
    when I open Cydia on my ipad2, it shows below 3 messages in red and after that nothing works in cydia:
    x. wow, you exceeded the number of package names this APT is capable of.
    x. problem with mergelist /var/lib/apt/lists/apt.thebigboss.org_repofiles_cydia_dists_stable_main_binary-iphoneos-arm_packages
    x. the package lists or status file could not be parsed or opened.
    Anyone can help how to solve this problem?
  2. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,225
    Close Cydia out, fully (via the Multitask bar) and then reopen Cydia. Go to the Changes tab and hit the Refresh button. See if that helps?
    If not, try closing Cydia again and then respring the iPad. Then, try the above again.
  3. AAA
    AAA
    Nov 18, 2011
    40
    I tried both but still the same problem... Reloading and same error messages...!
    Any other solution?
  4. AAA
    AAA
    Nov 18, 2011
    40
    Any other solution for this problem?
  5. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,225
    Have you tried removing some repos (sources)? You must have too many loaded for Cydia to handle. So, get rid of some, but make sure you don't deleted the five defaults:
    BigBoss
    Cydia/Telesphoro
    Dev Team
    Mod Myi
    ZoTTD & MacCity
    See if that helps...
  6. AAA
    AAA
    Nov 18, 2011
    40
    Excellent
    I removed some of the sources and problem solved
    Thank you very much Marylin
/var/lib/apt/list/apt.modmyi.com
/var/lib/apt/lists/apt.modmyi.com
cydia problem with mergelist
cydia problem with mergelist /var/lib/apt/lists
problem with mergelist /var/lib/apt/lists/apt.modmyi.com
problem with mergelist bigboss
problem with mergelist cydia
problem with mergelist/var/lib/apt/lists/apt.thebigboss.org repofiles
proplem with mergelist/var/lib/apt/lisis/apt.modmyi.com dists stable
