Problem connecting to wireless home network
colinicky
UK
I have an ipad 1 which up untill a week ago has always connected to my home wireless network (Sky) with no problems but now it says it is connected (little wireless symbol full strength) but will not access the internet etc .If I go into the settings then I have it set on DHCP which to my knowledge it has always been on but the IP Address is not correct for the sky router, the Subnet Mask is also different .
I have an old ipod touch that still connects everytime as does my phone & they ip & subnet on those match the router .
Any ideas please ?
TIA
Colin
Gabriel1
Cranbrook, Kent, UK
Might be worth going into the Settings App, choosing wifi, then your network then choose to forget your network. Once this is done go back in and join the network as if from new.
C
colinicky
UK
Tried that thanks but still no joy. Have tried it using my mobile phone as a hub via mobile broadband & it works fine so the ipad works with others, the sky router works with other but they will not work together !
Gabriel1
Cranbrook, Kent, UK
Have you tried rebooting your router?
C
colinicky
UK
Thans for the link . Unfortunately that is not the problem either. Have managed to overcome it by entering the correct ip & subnet address in the "Static" tab of the network settings, Don't know why it comes up with the wrong ones in "DHCP" though .
