Problem after jailbreak
Discussion in 'iPad Hacking' started by hilfer, Jul 22, 2012.
  1. hilfer
    hilfer
    Dec 31, 2011
    52
    Hi all:
    Running vers. 5.1.1. on my Ipad 1 I decided yesterday to jailbreak it with absinthe.
    Now I can't open any application, dropbox,gmail, airvideo....nothing , only a little twinkle and that's all.
    Shall I restore my device to remove jailbreak ??
    any ideas ??
    EDIT: I think I know what's wrong.For any reason the jailbreak has uninstalled almost all aplications I had.
    Icons were still there but they were not installed anymore !!!!
    Juts installing everything again.
    #1 hilfer, Jul 22, 2012
  2. johnodd4
    johnodd4
    Jul 22, 2012
    16
    I have to say it time and time again the reason you got shafted is because you dont carefully read the instruction's.
    Listen up.
    1. The jailbreak doesn't work on 5.1 and on 5.1.1 it has some new dd protocals that block the sim card on the 4g and 3g models it also has some new commands that they don't quite understand yet that cause firmware corruption.
    this is why you dont jailbreak read up on every forum before you jailbreak
  3. Mickey330
    Mickey330
    Staff Member
    Aug 30, 2010
    11,892
    2,225
    I do not know from where you are getting your information, but it is flat out wrong. There is a jail break for virtually any iDevice currently running iOS 5.1.1 and it works fine.
    Please don't post without further checking on the facts. Thank you.
  4. hilfer
    hilfer
    Dec 31, 2011
    52
    That was the only problem I had.
    Everything is working fine as before after reinstallation of all appls.
    Maybe I did something wrong during jailbkreak.
    #4 hilfer, Jul 23, 2012
  5. Totallylagit
    Totallylagit
    Jul 6, 2012
    163
    I suggest you do a backup and restore. I have had no problems on my iPad 3 and 1 both on 5.1.1
  6. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Sounds like you maybe did a restore of the backup from iCloud but didn't allow the apps to reinstall yet? They still have to reinstall once the restore from backup is "complete" (in fact it is only part complete!)
    Anyhoo, glad you found the problem and solved it yourself ;)
    Also, if you don't mind, I'll move the thread to the correct section of the site, since it relates to a JB device...
  7. Poser
    Poser
    Jul 2, 2011
    816
    27
    next time it happens, delete a free app, and then install it again.
    i think when you sync with your PC(sorry if i assume you have a PC), it will happen again. You should update your iTunes to the latest version.
  8. hilfer
    hilfer
    Dec 31, 2011
    52
    Thank you guys for all information.
    Everything is working fine now.
  9. johnodd4
    johnodd4
    Jul 22, 2012
    16
    actually i did check the facts and i have jailbroken several apple devices the reason i said to do the research is there are outdated information on several sites that have the older beta versions linked to it these versions caused the firmware corruption and the reason i know this is because i had to take my iphone in because of firmware corruption thanks to the beta versions of the jailbreak also my ipad as well i just warned becarefull and do a lot of reading before you install
  10. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Well, we welcome your contribution, but we pride ourselves on not giving misinformation to our members. Stating that there was not a 5.1 or 5.1.1 jailbreak is factually incorrect and very out of date. Our many stickies in the hacking section, which we work hard to keep as up to date as possible, would back that up. For example - http://www.ipadforums.net/ipad-hacking/24377-jailbreaking-methods-ipad.html
    Please don't judge the quality of jailbreaking information in our forum against the poor standard of the majority of other forums! If you want to know the facts.... read our stickies :)
dropbox not working after jailbreak
how shall i understand if my iphone is hack or not
ipad 3 problem after jailbreak
ipad stock wallpaper corrupt
problems after jailbreak ipad 1
