Printing help
mikewigan
Hi everyone, can you please tell me if you can set the iPad to print wirelessly to a Epson wireless printer...???
barlowbrian
Essex, uk
Hi you would need to connect the printer to your home network/router wirelessley and then you can connect to the network printer, it can be done it just needs time in setting it up first. Details for setting up the network can be looked at through your computer help? Good luck
Tim SPRACKLEN
The third-party printing app 'PrintCentral' or 'PrintNShare' can print wirelessly from your iPad to virtually any WiFi printer directly and to absolutely any printer via your (WiFi) PC or laptop. I use PrintCentral to print to my WiFi Samsung printer, but it should have no problem with your Epson.
M
mikewigan
Hi Tim
I've seen them apps but how easy is it to print a document on the, example if I open a PDF document in iBooks , how do I then print it.
Cheers
Mike
heinshe
mikewigan said:
Hi Tim
Cheers
Mike
I have these applications and they will not let me print It prints but the paper is blank
mikewigan said:
Hi Tim
Cheers
Mike
It should work just fine. In iBooks you tap on the right-pointing arrow, select 'Print', select your printer and tap print again. I just used this method to print a PDF from within iBooks.
Just keep in mind, that PrintCentral doesn't offer the In-App printing anymore. Only Print'N'Share will let you print directly from apps, such as iBooks.
M
mikewigan
Just got print n share and that appears to work fine.
Thanks for everyone's help.
Regards
Mike
