1. Due to the recent site upgrade, the iPadForums (iPF) App will no longer work. The new iPadForums.net website has been designed from the ground up to work perfectly from any mobile, tablet, or desktop computer using the built in internet browser. Create a shortcut to iPadForums.net on your home screen by following these steps: Create an icon for iPadForums.net
Print Agent PRO – advanced printing on network printers
Discussion in 'iPad App Announcements' started by Nataly, Aug 10, 2012.
  1. Nataly
    Offline
    Nataly iPF Novice
    Sep 5, 2011
    24
    Ratings:
    +0 / 0
    [​IMG]
    Print Agent PRO for iPad on the App Store
    To test the compatibility with your printer you can download a free application Print Agent Lite.
    What Is Print Agent PRO?
    Print Agent PRO is an advanced application that lets you to store files, read and print wirelessly to most of the WiFi, network and local printers, connected to a computer and shared for access in local network.
    How It Works
    Print Agent PRO is the best way for you to print any document you want, including emails and email attachments, right from your iPad without any wires.
    Printer Test Wizard
    Use the Test Wizard to view and test all shared printers in your local network. You can mark them for further use and select required printer from Print Settings window.
    Get Files from Numerous Sources
    Once installed Print Agent PRO appears in the “Open In…†list for many popular file types. This allows printing email attachments form Mail, documents stored in Dropbox, opened with Safari and popular Cloud storages applications, such as MobileMe iDisk. Also you can easily copy documents to Print Agent PRO over USB using iTunes File Sharing.
    File Manager
    Print Agent PRO contains a convenient file manager to get access to your documents, sort them, organize by folders, send by e-mail or delete if necessary.
    You can transfer stored documents to any application that supports Open In..., such as Pages, Numbers and Keynote for editing. PDF files could be opened in iBooks for expanded reading experience.
    New User Interface
    With user friendly interface all activities are clearly visible – you can see whether the printing process started and can stop it in one tap if necessary.
    Flexible Print Settings
    Print Agent PRO provides two ways for printing your documents:
    Choose Quick Print optinon to print with the default settings - document orientation, paper size according to your regional settings, printing to the currently selected printer.
    Use Print Settings dialog to set all required settings and preview a document before printing.
    With Print Agent PRO you can read, print and share:
    Pages, Numbers and Keynote documents
    Adobe PDF files
    Word, Excel and PowerPoint documents
    Pictures and Photos
    Contacts list and vCards
    Emails and Email attachments
    Web pages
    Documents from Dropbox or official MobileMe iDisk application
    Files from many other applications
    Print Agent PRO for iPhone is also available on the Apple App Store
print agent lite test wizard is currently unavailable
print agent pro can't find printer
