Power point
Discussion in 'iPad 3 Forum' started by KevTN, Apr 3, 2012.
  1. KevTN
    KevTN
    Apr 2, 2012
    14
    Hello, new to iOS. I am in the process of developing power point presentation I am giving in a couple of months. Is there an app available that will allow me to use and edit my work on both my win 7 and on my iPad 3? I will have to save in power point format.
  2. Texas Holders
    Texas Holders
    Mar 15, 2012
    47
    Keynote will open ppt files and save to that format as well.
  3. lasllcap
    lasllcap
    Apr 2, 2012
    25
    If you value the formatting effort you put into the presentation, I would recommend QuickOffice HD; with the exception of interfacing, it runs MS office documents virtually natively. put your doucuments in Dropbox or other cloud server (probably not iCloud. apple being what it is) and have access to them anywhere you can connect to the internet. Any changes made are instantly reflected on all machines using those documents.
  4. KevTN
    KevTN
    Apr 2, 2012
    14
    Thanks for the information. I will look into both. I have had keynote mentioned to me and I have used QuickOffice on my android tablet and it didn't work out too well, but maybe in the iOS it will? I do have dropbox.
    I appreciate both of your answers and will look into both of these apps.
    Have a good day.
  5. lasllcap
    lasllcap
    Apr 2, 2012
    25
    Although I can not comment on PP, I have been using QO on my iphone for quite a long time to keep business records (excell, word primarily) and it has been swell. Not as much time on the Pad though. Maybe it is Android?
  6. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,415
    435
    Why not pay $5/month for a few months and use Onlive Desktop Plus? You can put your powerpoint file on your dropbox folder and then use Powerpoint on your iPad to work on both platforms.
    You will need a good connection (wifi is preferred since this is streaming a windows desktop and office apps to your iPad) and a blu-tooth keyboard. The $5/month gets you priority access to their servers. You can try it out for nothing.
    [​IMG]
    #6 AQ_OC, Apr 3, 2012
  7. brunodjkj
    brunodjkj
    Mar 26, 2012
    40
    Online desktop plus sounds very interesting
  8. AQ_OC
    AQ_OC
    iPad Wizard
    Apr 28, 2011
    6,415
    435
    Onlive desktop. Don't ask me why they use that name. It works, though.
  9. Wokiebear
    Wokiebear
    Feb 6, 2011
    173
    7
    Go look at a new app just out in iTunes called SlideShark -- is made to present PowerPoint presentations. I haven't done much with it to see if you can edit in it. Right now it's a free download.
  10. KevTN
    KevTN
    Apr 2, 2012
    14
    Thanks folks...
do power points work on apple ipad
how to use powerpoint on ipad 3
power point for ipad
power point ipad3
powerpoint for ipad 3
powerpoint on ipad3
powerpoint template for ipad 3 free
ppt edit ipad
ppt on ipad 3
