Power Adapter and USB Cable?
Discussion in 'iPad 3 Forum' started by barmar, Aug 20, 2012.
  1. barmar
    barmar
    Aug 18, 2012
    15
    Are the USB cords/cables for the iPod Touch (4th Generation) and iPad 3 interchangeable and can you also use the iPod power adapter to charge and iPad3 and vice versa?
  2. col.bris
    col.bris
    Staff Member
    Mar 25, 2010
    5,883
    690
    Welocome to our forums...
    The power supply charger for the iPad is 10v it can be used to charge iPads, iPhones and iPod's. You cannot charge the iPad correctly with the iPod charger as it is low voltage. It would take a long time as it is low powered. Cables can be interchanged.
can ipod and ipad cables be interchanged
