please help, iPad won't charge
T-Time3
Somewhere I Belong
please guys, help me out..
my iPad seems won't charge..:(:(
i charge using the original 10W USB power adapter from apple.
and i plug it into the wall (not pc).
this is my iPad display:
it's not charging right ?
so, what is the iPad display looks like when it's charging ??
really need your help guys..:(
thanks in advance
j0yful
if it's charging, the battery icon has a lightning icon cutting through it.
iPadCharlie
Try unplugging the cable from your iPad and plugging it back in. If it is not in the docking port perfectly straight, this could happen. When it is plugged in properly, you should here a "tweet" sound. You will know it when you hear it!
col.bris
Gold Coast , Queensland Australia
Try plugging into computer with iTunes launched if it does not charge it is an iPad problem if it starts charging then you have a faulty power charger. It also may be a bad cable
Col
T
T-Time3
Somewhere I Belong
j0yful and 1991-C4, thanks so much for the help..
appreciate it..
i figured it out already, the docking part is not perfectly straight.
problems solved now.
mod, u can delete this thread..
:D
iPadCharlie
Good show!
The mods generally don't delete posts unless they contain "objectionable" content. Besides, if they leave it up, perhaps someone else can benefit from your experience!
wanderlust
va
Thanks for the advice! Just figured out this is the reason my iPad wasn't charging either. Looks like my iPad cover was keeping the charger from plugging in correctly.
