Please help! Error code 300-5
Lizzy and proud
Cincinnati, OH
Hi I'm Lizzy I recently moved from tampa, FL to Ohio. The reason I joined is because my iPad :ipad-front: won't let me whatch abc player it is saying error code: 300-5 and I really want to watch my show whatnshouldmi do to fix it. My iPad a 32gb wifi first generation iPad I don't know that matters tho. If you could help me that would be great.
Tim SPRACKLEN
Good to hear from you. You’ll find a whole bunch of iPad enthusiasts in this Forum who are only too willing to help other iPad owners and to hear of their experiences. Don’t be afraid to post any questions you may have or use the ‘Search’ button near the top of the Forum web page. I usually find I discover one new interesting and useful piece of information about my iPad every day - and often not even what I was looking for!!
Hope to hear from you soon with your thoughts about the iPad.
Have fun and enjoy your iPad
If you don’t already have it you can download a copy of the iPad manual for free.
Apple - Support - Manuals
Please read the rules too!!
Adevenberg
Oregon
Did you ever figure out how to fix the error? I am having the same problem. I reinstalled the abc app and turned my iPad on and off twice and I still get the error. I want to watch my shows!
Josh S
Nc
Same problem
I am having the same problem. Any fix yet?
maryc7383
Guam
Go to the App Store and update the app. It worked for me, hope this helps!
JenCR
Missouri
I am having this issue too. I checked the App updates and there is not one for this app so that is not the answer for me. It's frustrating!
Sophary
Georgia, USA
I am having the same problem , I thought it was my internet connection, but it seems it's the app itself. I have tried deleting the app and it worked for awhile but then the code came up today . I am going to try an go to ABC.com and see if I can watch my show there. When I first got my IPad you had to use the app or I just did not know what I was doing . Let me know if anyone has found out any new solution , I will also respond if I can find anything.
Buffalobee
I had to change my restrictions under the settings to allow all shows and all movies. I had it restricted to PG. After I removed all restrictions on the iPad settings, it worked. Settings/general/restrictions. This may be totally random but it did the trick for me. FWIW, I find it odd, because the show that I was trying to watch had PG rating. But this helped me. Let me know if anyone else has luck with this fix and we can maybe confirm that it wasn't random.
maryc7383
Guam
Compatibility shows the app requires iOS 5.0 or later. Check on that if you haven't done so already. Hope this helps! Good luck!
