PC connection problems
Discussion in 'New Member Introductions - Site Assistance' started by turner, Feb 15, 2011.
  1. turner
    turner
    Feb 15, 2011
    6
    I have had my IPAD since before Christmas and initially set it up fine. After downloading some apps I am no longer able to connect to my windows XP computer without the computer crashing. I have tried lots of things and the Apple support line has not been any help. If you know of any suggestion, I sould like to hear it. Thanks, Turner
  2. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    Could I ask a couple of other questions?
    I guess you are using the latest version of iTunes - i.e. at least 10.1?
    Does the PC crash immediately you connect the iPad or when iTunes boots or when a sync operation is occurring?
    Does XP crash giving you an error code?
    I'm sure that, over the next day or two, Forum members will be able to sort this problem out, so don't panic!
  3. turner
    turner
    Feb 15, 2011
    6
    Blue screen error code
    Thanks, Tim,
    Here is the error code:
    STOP:0X0000007E (0XC0000065,0X00000000,0XBA5077C8,OXBA5074C4)
    Before that there is a message saying a problem has been detected and windows is shutting down to avoid damage to the computer.
    Yes, I am using the latest version of ITunes.
    The crash seems to be when ITunes recognizes the ipad.
    #3 turner, Feb 16, 2011
  4. Snafu169
    Snafu169
    Nov 29, 2010
    31
    Post your system specs (model,ram), also is your XP completely up to date with SP3 and updates.
    Make sure you post the entire error message
    Have you altered any startups or services in msconfig ( if you don't know then it's a no)
    Did you try different USB port?
    #4 Snafu169, Feb 26, 2011
  5. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    This may sound like a silly question - so please don't be offended - but why are you connecting your iPad to your computer?
    I say that because, as several Forum members have suggested, it's hardly worth connecting your iPad to your PC simply to 'back up' the iPad.
    For one thing, backing up can take a long time. For another, since iTunes and the App Store keep a record of all your purchases, even if you 'lost' everything and had to completely reset your iPad, you could upload again all your apps and iTunes purchases. So all you really need to back up are any documents, presentations etc that you might be working on. Photos - well, I guess you've got those on your PC anyway.
    Backing up documents etc can be done either directly to your PC over WiFit using, say, GoodReader or another third-party application or via a 'cloud server', such as Apple's MobileMe iDisk.
    OK - I know this doesn't really answer your question (well, actually it doesn't answer it at all!) and if you really want to sync contacts and appointments all the time between your PC and your iPad it's definitely not a solution, but I just thought I'd mention it.
    Going back to your original problem, as the previous poster suggested, maybe trying a different USB port (if you have one), checking you have the latest XP Service Pack update is the next step.
    Keep in touch and let us know how you get on.
  6. Snafu169
    Snafu169
    Nov 29, 2010
    31
    I hardly ever connect to my pc, the only reason would have been for images, but I usually just upload those to sites like flicker, facebook or google etc..
    Never the less it's still worth fixing, especially if related to out of date software in OS or drivers of some sort ( that's why entire error has to be posted)
  7. Tim SPRACKLEN
    Tim SPRACKLEN
    iPad Legend
    Jan 3, 2011
    15,235
    122
    Yes - you are right - it's definitely worth fixing!! For one thing, it would just nag at the back of my mind all the time. I can't stand things 'not working'.
    I'm no good with Windows error codes, so I bow to your superior knowledge. Anyway, for the second day running, my brain is only operating at ½ its normal clock rate and it's only a single core processor.....in fact, it feels like an Intel 4004 some days...
  8. Snafu169
    Snafu169
    Nov 29, 2010
    31
    well superior lol I don't know.... 4004 are you showing your age :p?
  9. turner
    turner
    Feb 15, 2011
    6
    Error screen when trying to connect ipad to pc
    Thank you everyone. Here is the entire screen info that comes up on the blue screen when I try to connect the ipad:
    "A problem has been detected and windows has been shut down to prevent damage to your computer.
    If this is the first time you’ve seen this stop error, restart your computer. If this screen appears again follow these steps.
    Check to be sure you have adequate disk space. If a driver is identified in the stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters.
    Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select safe mode.
    Technical information:
    STOP: OXOOOOOO7E (OXCOOOOOO5, OXOOOOOOOO, OXBA5077C8, OXBA5074C4)
    Beginning dump of physical memory
    Physical memory dump complete
    Contact your system administrator or technical support group for further assistance"
    Thanks, again, Turner
  10. Alfsbrother
    Alfsbrother
    Oct 20, 2011
    7
    I noticed the date on this enquiry above, and I wondered if you solved the problem of your PC crashing when connecting your IPad. I now have exactly the same problem, I tried changing USB's, disconnecting web cam and so far no joy. Help!! as I would like to download family pictures etc. onto the IPad so I can bore other people when away from home and visiting relatives. Any body's advice or solutions welcome.
always on pc connection error
computer crashes when ipad connected
error de ipod 0xc0000065
ipad computer connection problems
ipad connection to pc problem
