Password problem
leilaw
Trying to upgrade my software and it is asking for a password. Have tried everything I can think of but nothing working. Is there a way to reset the password because I can't find it.
scifan57
Regina,Canada
This is called Activation Lock and it means that your update cannot be completed unless you input your Apple ID and password.
Try the password you use for iTunes and app purchases to see if it works.
L
leilaw
Unfortunately that's exactly what I was trying and it isn't working. Should they be the same or could they be different? If they are the same I'm not sure what is wrong because that is the password I'm putting in.
J. A.
Apetlon, Austria
If you have a different iCloud account than your Apple ID, try the password of that account.
Or try the passcode that you have to enter every time the iPad is locked and you want to unlock it.
L
leilaw
tried that. Didn't work.
J. A.
Apetlon, Austria
If that's not the case, try to disable the passcode lock in Settings - Passcode.
abababababab
Singapore
Try this : From Settings > iTunes and App Store > Account, sign out of your Apple ID. Then do a restart or hard reset of the iPad, then again log-in from the same place.
Good luck!
