omg pls help
Discussion in 'iPad Help' started by vivvoo, Dec 31, 2010.
  1. vivvoo
    vivvoo
    Dec 31, 2010
    Hi,
    yesterday I had to rejailbreak my iPad, and it worked out fine. I was on installous and it crashed. I figured I would just reboot it. However when I tried to reboot, the apple logo would show up and then after a long while the little loading thing shows up and it just freezes. I had to hold the power button and home button together to get it to shut off but it just keeps doing the same thing. I tried connecting it to my computer so I can try restoring it, but Itunes would pop up and freeze as well. My computer doesn't even recognize the ipad.
    Pls help me pls! I'm not really good with computers so simple and thorough explanations would be greatly appreciated. thanks so much in advance.
  2. Yakuzagang5
    Yakuzagang5
    Nov 9, 2010
    122
    Well you should have read that it's still tethered, and you have to go and on redsn0w select just boot tethered. Don't worry about what state your iPad is in, just plug it into, and go through the steps to just boot tethered and you should be fine.
  3. vivvoo
    vivvoo
    Dec 31, 2010
    I did the "just boot tethered" part yesterday. Let me try again. I hope the ipad responds.
  4. vivvoo
    vivvoo
    Dec 31, 2010
    btw, it rebooted fine last night only up until installous crashed.
  5. vivvoo
    vivvoo
    Dec 31, 2010
    Yakuzagang5 you are the best! thanks! omg I feel so much better now.
