No sound??
Discussion in 'iPad Help' started by Rex126, Mar 3, 2011.
  1. Rex126
    Rex126
    Mar 3, 2011
    I have an iPad which I like a lot , got it December. Every things been fine till today. For some reason my volume buttons won't work and my audio does not work as well. When I boot up the iPad, as everything is finishing loading, the sound and volume buttons do work, but then within five seconds just stop responding and not audio. I don't get it. When I double hit the home button the volume slider is there but there is no circle to slide, as if the iPad has no way to output sound. I have tried a hard reset, restore, and turn off and back on. It did not fix the the issue. Any suggestions ???? I would appreciate any help. Thanks!!!
  2. Wesley18
    Wesley18
    Mar 3, 2011
    Have you tried the sound lock above the volume switch on the top right side?
  3. Rex126
    Rex126
    Mar 3, 2011
    Yea the sound lock is unlocked :( and I just woke the iPad up right now and had sound/volume control for 2 sec and the it was gone again ..,sigh....
  4. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,134
    7,352
    Sounds like hardware. You'll probably have to talk to Apple tech support.
ipad volume and camera not wor
my sound effects wont work on ipad
sound won't work on ipad
sound wont work on ipad
the volume in my ipad dont want to work
volume wnt work just sound afftects pops up ipad
volume won't work on ipad
volume wont work on ipad
what to do if your ipad sound wont work
why wont my volume work for video links on ipad
