No sound for my iPad. Help!
Discussion in 'New Member Introductions - Site Assistance' started by Maceyw, Jan 12, 2012.
  1. Maceyw
    Maceyw
    Jan 12, 2012
    I just got my iPad today. I have reset it and played with the general settings. Nothing i have done has worked. I still have no sound. When I got to general sound settings I can hear the demo of notifications but that's it. So then I decided to plug in headphones to see if I could hear anything. And I could. All sound worked. Please someone tell me how to fix this so I don't have to use headphones.
    Thanks for any and all help.
  2. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,837
    1,306
    Hi and welcome to the Forum!
    You haven't inadvertently turned on the mute button have you, it's the little switch just above the sound control.
    Also look at the control which is found when you bring up your multi task bar. Do the 4 finger swipe up or double press the home button and you will see your multi task bar along the bottom, swipe right as far as you can go and you will see a volume control slide here. Let us know if that was it.
    Once again we welcome you here and are so pleased you have joined us
  3. Maceyw
    Maceyw
    Jan 12, 2012
    Thanks for ur help. It's not the. Mute key on the side. I went to the multi task bar and it showed where the sound should be but would not let me change it...
  4. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,837
    1,306
    It won't let you change it? That's very strange. I think a restart and or reset is in order here.
    Restart: Press and hold the power off button, the one at the top right. You will see a slide appear to power off, slide this and the screen will go dark and a Whirly will appear. When the Whirly disappears your iPad is now off. Press the power button again until the Apple logo appears, this will take a few seconds and your iPad will restart. You should restart your iPad occasionally also as it will keep it running well. Now see if it is operating. If not a reset is the next step.
    Let us know how it goes.
how do i get sound from my ipad
how to rest no sound on my ipad
my ipad has no sound
my ipad won make sound
my ipad wont make any sounds
my ipad wont make sounds
where is sound on ipad
where is the sound on my ipad
why wont my ipad make sound
why wont my ipad make sounds
