I have the WiFi only version and it works great on both home WiFi and bluetooth hotspot with my iphone 3GS. To use the iPhone hotspot I have to go into ipad settings and manually press to connect it to the iPhone which I guess is a good thing to prevent using 3G data plan for netflix or something like that by mistake...
The problem is that if I just close the cover on the iPad and then go home, forget about it and start using the iPad it will still use the 3G on the phone instead of my WiFi.
Any known way around that?
