New to forums and iPad. Have questions and need help.
Novakingwai
Hello. New user and 1st time site user. First let me start by saying that I am an Android guy. My main phone and love will be Android.
*hides behind indestructible wall with my trusty 0.45 in case anyone manages to get around it*
Now that that's out the way, I just purchased an iPad Air. Why? Because I want to have it propped up on an exercise bike to entertain myself while I work out. I've had Android tablets up there before. I got rid of them because I never used them, now I never use the bike, so to get back into using the bike I decided to get a tablet. I got a 16GB iPad Air with Sprint service from Craigslist for $280. Can't beat that. And I figure when I'm done it will keep a high resale value.
I want to jailbreak or hack or whatever you call it. I loved rooting and installing ROMs and apps that Google didn't allow on my Note 3, Tab Note, and older Android phones. Where do I start for an iPad? I have iOS 7.1.1. I would also like reommendations on what you can do with a hacked iPad and what kind of apps are available that aren't Apple approved.
The OB
Adelaide, South Australia
Hello Novakingway and welcome to the forum. Now that you have taken a bite out of that Apple I predict you may well be struggling to keep insisting that you are an Android guy, not that there is anything wrong with that:)
I'll move your thread over to our iPad Hacking section which is going to give you a wealth of information about the possibility, and the enjoyment of jailbreaking your machine.
Again, good to have you here, and enjoy the forum!
Andrew
Mickey330
Western NY state (USA)
.... [snip for space] .....
Hi, and welcome to iPad Forums!
That iPad can be jail broken on iOS 7.1.1 using the PanGu Jailbreak Tool. Here's a link to a jail break guide for that tool (written by one of our fellow members): http://www.ipadforums.net/threads/how-to-jailbreak-ios-7-1-x-using-pangu.122355/
It's a pretty straightforward process, but don't hesitate to holler if you need more info.
Once you've jail broken the iPad, you will then have access to Cydia, the jail breakers "App Store." There you will find all the goodies (paid and free) that jail breakers can install on their iPads to make them as they wish.
In addition, here's a link to a thread that talks about the various tweaks and such that can be used on an iPad. Makes for some good reading and may give you some ideas: http://www.ipadforums.net/threads/ultimate-list-of-jailbreak-tweaks.25824/
I do need to give you one word of caution. The version of iOS your iPad is on is jail breakable. However, iOS 8 is not. So, you will not be able to upgrade the software once you jail break. Once you jail break, you will end up playing a dodge game with Apple as they release updates and you work to avoid them (until the new update is jail breakable). Again, this is just a caution because there are no do-overs.
Again, welcome and good luck with your new iPad.
N
Novakingwai
Andrew
Thanks. I already got this jailbroken and have started installing tweaks. This iPad isn't convincing me to drop Android. I'll keep my phone that I use every day as Android. I like the customization it offers. But iPad is pretty nice with some of the exclusive apps, good battery life, and universal app compatibility.
willerz2
New York
It takes a while to really pull a definitive perspective on the differences and likes or dislikes. You don't really explore everything at once and it takes time to tweak the device to your liking so that it's at a state where you can compare two devices. However, you always have to keep in mind that you're comparing two completely different OS and devices. There are different priorities and possibilities between iOS and Android.
N
Novakingwai
How can I uninstall the stock apps? I will never use some of them and I hate looking at them.
In particular, iBooks, FaceTime, Newsstand, iTunes Store (do people still pay Apple for music and shows?), Calendar, Reminders, Contacts, Messages, and Notes. Will removing any of these affect the system?
I am aware of being able to create a folder and hiding these apps in it, but again I want them gone if I don't need them.
scifan57
Regina,Canada
I'm afraid that there is no way to delete the stock apps. They're built into the iOS and can't be removed. With a jailbroken iPad they can be hidden but it's not recommended to go into the system files and actually start deleting things. If you do, there's the chance you could render your iPad unusable.
J. A.
Apetlon, Austria
FaceTime, Podcasts and iTunes Store can be restricted, then you won't see them on the iPad. Go to Settings - General - Restrictions and disable them.
scifan57
Regina,Canada
You can also restrict the App Store, Safari, and Camera in the same way. These apps are, however, the only ones that can be hidden in this manner.
N
Novakingwai
Ok one last question. I see wireless storage solutions for storing movies, pictures, and documents so you can stream them to the ipad. Is there a way you can store apps off the ipad? or the actual app .ipa installer so I can quickly migrate apps back and forth? Some apps are 1GB+ and I don't want to have to redownload them every time I want to play them and I'm out of room.
scifan57
Regina,Canada
I'm afraid that an app has to be actually installed on your iPad in order for it to be used. There's no way to open and use an app that hasn't been downloaded.
N
Novakingwai
Is there a way to save the app file, transfer it, then reinstall? In Android you can save an app as a .apk, move it around, and just move it to your device to install it. Can you do that on iOS?
scifan57
Regina,Canada
I'm afraid not. The only ways to install apps on a different device is to download them from your purchased list or sync them from iTunes on your computer. The device, of course, has to be tied to the same Apple ID that was used to originally purchase or download the app.
chezlong
I'm brand new (joined today) and can only seem to reply to posts, not ask my own. I'm not Novakingwai, I'm chezlong and have a question about formulas on Numbers
