Need help.
Discussion in 'iPad Help' started by Ga Men, Jun 25, 2010.
  1. Ga Men
    Ga Men
    Jun 6, 2010
    I have my iPad 3G have been jailbroken & it's been running good but last 2 days I see some update on Cydia I just go ahead update them after that cydia ask to restart springboard & after my ipad restart it go to recovery mode & just stay there even I turn it off (by holding power & home button as the same time) it still go back to recovery mode. I try to restore thru my iTunes 9.1.1 & iTunes show me an error 9 & it put my iPad back on recovery mode. What I did wrong? Any advide? Please help. Thans in advance.
  2. MikesTooLz
    MikesTooLz
    iPad Ninja
    May 7, 2010
    2,361
    20
    Put the ipad into DFU mode before restoreing.
    #1 connect to itunes
    #2 hold both home and sleep/wake buttons untill it reboots
    #3 once the screen goes off to reboot count to 10
    #4 after counting to 10 release the sleep/wake button but continue holding the Home button.
    itunes should pop up a message saying it found an ipad in DFU mode and you can restore it.
  3. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    I think I am having the same issue. I wish I would have read this before I installed that update. I just got the little "thinking" circle.
  4. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    Actually I just did a hard reboot and was patient and it loaded np
  5. Ga Men
    Ga Men
    Jun 6, 2010
    I do the same as you said but when I try to restore iTunes show me an error #9 & it stop & put it back to recovery mode again. Any more advise?
  6. thehatguy
    thehatguy
    May 12, 2010
    125
  7. Ga Men
    Ga Men
    Jun 6, 2010
    Thanks let's me try connect it to different USB port with a different sync cable see it may work, if not can I try with another computer with iTune 9.2?
  8. Ga Men
    Ga Men
    Jun 6, 2010
    It do the samething with different USB port & cable. Should I try with iTunes 9.2?
  9. mslammers
    mslammers
    Jun 14, 2010
    174
    I guess if I were you, I would see if you can get an Apple store to help you. I don't know where you are located. Then I would stay away from Jailbreak for a while until you get some more experience. Just me of course, you are taking some chance with Jailbreak though.
  10. Matth3w
    Matth3w
    iPad Ninja
    May 26, 2010
    2,017
    Doubt he would want to do that since his iPad is jailbroken and voids the warranty...
i pad updates have been holding for 2 days
reloading pringboard on ipad2
restarting springboard on ipad
