Need help with white icons
Discussion in 'iPad Hacking' started by Pichon617, Jul 4, 2011.
  1. Pichon617
    Pichon617
    May 7, 2011
    53
    I renamed a few apps in ifile now the app icon are white. I need help can any1 help with this issue.
    Sent from the iPad you lost & I found 32g 3G/wifi jb w/redsn0w
  2. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    Does the app open?
    Make sure you only changed the "CF bundle display name" string, and not anything else. Sounds like the "CF bundle executable" line got edited.
    Did you save a backup copy of the file?
  3. f4780y
    f4780y
    Staff Member
    Sep 11, 2010
    7,113
    652
    Rename them back?
  4. graywolf
    graywolf
    iPad Super Guru
    Aug 22, 2010
    3,651
    35
    What a wonderful idea! :)
  5. Pichon617
    Pichon617
    May 7, 2011
    53
    Thanks to all who helped
why is my ifile app white
