I'm tearing my hair out over this "Notes" App of Apples. Does anyone here know how to "Cut" text since it's not an option? Is the only way to just backspace over all the paragraphs? I'm about to give up on this lame app.
Press your finger down where you want to start and some of it will turn blue and say select. Drag the button to where you want to stop. It should say cut, copy, paste. I'm not too technical but it seems to work.
Bobbi
I already did that or I wouldn't have known there was no "Cut". There is only "Copy" and "Paste" on Apple's Notes. No option to Cut.
I cannot find a cut command. The delete button on the key board is the only option. Try holding the button down to rapidly delete long blocks of text. It's a bit hit and miss.
There are other useful note making apps available, such as Evernote.
In Notes:
The Cut and Paste options only show when you are editing the note; when you can see the cursor in the note and the keyboard is visible (if you're not using an external keyboard). I you are merely viewing the note you get Copy and some viewing/reading style options like Define and Speak.
So, the first thing you do is tap the note to get into edit mode. Then tap and hold for the selection optinos. After you've selected something, you'll get the Copy, Cut, and Paste options.
By the way, this is true of most editor apps, including Evernote. You won't get edit style options like Cut and Paste until you are editing the note.
That's not been my experience with the native Notes app. Even in edit mode, the offering of copy, cut, etc., varies.
What can I say? It's always been consistent for me. In view mode you can Copy and a few other things. In edit mode you can Copy and Cut if something is selected. You can Paste if there is text in the clipboard.
Pretty much every text edit/note app I've used works this way. I'm pretty sure it's a part of the API that almost all developer's use.
Then again, Notes is not my most used app, so I can't say I tested it exhaustively.
I've had another thought (or unreasonable facsimile). One of the early iOS 6 versions had a problem with selected text options in iBooks if the Speak Selection option was turned on in the Accessibility settings. I suppose it might affect the Notes app as well, since it has the Speak option.
Since you are jailbroken (if memory serves), you might be running that version. If the problem is consistent enough to test, you might try turning OFF the Speak option and see if it makes a difference.
And though I hate make suggestions on a topic I have no experience with, it might be worthwhile to review any tweaks you have going that would affect the keyboard or text editing environment.
I find it hard to believe that Notes is that glitch prone, and yet the problem remained below the tech blog (and my) radar. Though I suppose I could have simply missed those articles and posts. Can't read everything.
