need help with after screen install.
Discussion in 'New Member Introductions - Site Assistance' started by tglason35, Mar 10, 2014.
  1. tglason35
    tglason35
    Mar 10, 2014
    Hello. I just replace my ipad 3 screen now I cant slide to unlock. I have rebooted it and still nothing. is there something im not doing right?
  2. abababababab
    abababababab
    iPad Super Guru
    Apr 21, 2013
    4,147
    697
    Hello and welcome to iPF! Have a good time here!
    You can try resetting the iPad by pressing and holding the power button and home button simultaneously for about 20-30 seconds until the Apple logo appears. If this does not solve your problem, it may yet be another hardware problem and you need to make an appointment at the Genius Bar at the nearest Apple Store.
    Good luck! Don't forget to post the results!
    Once again, welcome to iPF and thanks for staying here!
  3. Ser Aphim
    Ser Aphim
    iPad Addict
    Nov 7, 2013
    1,024
    171
    In what direction are you sliding it?
  4. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,837
    1,306
    Hi and welcome to the Forum!
    I take it that you have replaced the screen yourself or had someone do it for you??
    What happened to the original screen, was it damaged due to a drop?? If so, there may have been other damage that you were not aware of or something else has been damaged during the screen replacement.
    All we can suggest at this point is that you do try the reset which abababababab has mentioned and let us know the results.
  5. abababababab
    abababababab
    iPad Super Guru
    Apr 21, 2013
    4,147
    697
    BTW, you can call me just by saying Abs. I know the name is to long, but I wanted to keep it same as the username of a game I play. While searching a forum for it, I came by this awesome place. I thought we had spoken about this over PMs! o_O
  6. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,837
    1,306
    Yes, we did speak about this on a pm and thank you, I will call you Abs......it's just that the OP may not have known who I was speaking about and that's why I did use your whole name here! ;)
    Although, at first I did use 7 ab's rather than 6. :O
    It's quite easy when I get the hang of it. :D
    But Abs it is!!
