Need Help Urgently
Discussion in 'iPad 2 Forum' started by MarkButter, Jun 24, 2012.
  1. MarkButter
    MarkButter
    Jun 24, 2012
    Right so I got a new app when I tried to download an update for it, it said unable to Download application but whenever I try to press Done or Retry nothing happens. The other parts of the screen aren't working either so I can't turn it off or anything
  2. MarkButter
    MarkButter
    Jun 24, 2012
    It didn't the only part of the Screen that is currently working is the done and the Retry ones
  3. Czevski
    Czevski
    iPad Addict
    Apr 24, 2011
    1,097
    473
    Did you try re-setting the iPad and then starting the download and update again? Re-set is hold the home and sleep button until the apple appears. This often clears hung-up processes.
  4. MarkButter
    MarkButter
    Jun 24, 2012
    Thanks Czevski that worked I didn't know you could turn off an iPad without using the screen :D
  5. skimonkey
    skimonkey
    Staff Member
    Sep 11, 2011
    18,940
    1,405
    Alright, Mark--you got it going...
    Great job, Czevski!! :D
