Need Help to restore iOS
J. A.
Apetlon, Austria
The iPad mini (first generation), Wi-Fi only, is iPad 2,5. That's what you have to select.
bazzle
Australia
Sadly it says Barrys ipad cannot be restored as the firmware file is not compatible.
J. A.
Apetlon, Austria
It's possible that your iPad is not a first generation mini, or it's Wi-Fi + cellular.
What's your iPad's model number? You can find it at the back of your iPad. It starts with an A, followed by four digits.
J. A.
Apetlon, Austria
That's the first generation mini, Wi-Fi only, so your description is right. The model ID is iPad2,5. That's the ipsw-file you should have downloaded. 9.1 is still signed by Apple, so I'm wondering why it wasn't working.
bazzle
Australia
Ive tried a few times using itunes , shift restore, then I select the file and get that message.
When I click more information it just takes me to the latest itunes store download , that I already have.
J. A.
Apetlon, Austria
Sorry, no idea what went wrong there. The software should be the right one, the procedure you described is right when you use a Windows computer.
