Need help streamlining my life
Discussion in 'iPad 2 Forum' started by kohler2009, Nov 14, 2011.
  1. kohler2009
    kohler2009
    Nov 14, 2011
    11
    I all, I am new here and would love your advice. Here is my situation:
    Just bought an ipad2
    My email is through gmail
    I use Microsoft outlook for email, tasks, calendar, and contacts
    My blackberry syncs to outlook
    How can I best get my tasks, calendar, and contacts to my iPad? Also, I am getting the iPhone 4s in December so I am trying to make that an easy transition as well!
    Thanks!!
  2. oberkc
    oberkc
    Jun 26, 2011
    218
    12
    It has been a while since I set mine up, but I believe the iTunes sync allows the transfer of contacts, calendar, and tasks from outlook.
    Use of Gmail is straight forward. Set up a new mail account on your iPad's built-in mail app. It will ask you for email address and password. Once given, the iPad sets all settings. Works well for Gmail. At least, it did for me.
    Alternatively, I think you can sync EMail with outlook directly through iTunes in the same way that you sync contacts, calendars, etc....
    Alternatively, one can sync outlook data with google and then sync iPad data (contacts, calendar, tasks, etc...) with google.
    Much depends on how much iTunes syncing you care to perform, and how much of the google applications you have, including google calendar and contacts.
  3. kohler2009
    kohler2009
    Nov 14, 2011
    11
    Great thanks! I havent explored iTunes yet but I will check it out. I think I figured out how to use gmail and my mail and calendar are showing up.
