Need Air Print help with HP 6500
Discussion in 'New Member Introductions - Site Assistance' started by sjones26, Jan 23, 2012.
  1. sjones26
    sjones26
    Jan 23, 2012
    My iPad and iPhone recogNize my printer but then won't print. When I turn it off and then back on it works for 15 mins then won't print any more.
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,859
    6,876
    It's probably a router problem. Turn off the printer, then turn the router off for a couple of minutes. After the router is back online try turing on the printer again.
    It is not a bad idea to check with your router's manufacturer and see if it's firmware is up to date. This is usually well hidden on the manufactures support pages, under downloads as often as not.
  3. leelai
    leelai
    Staff Member
    Apr 24, 2011
    24,828
    1,306
    Hi and welcome to the Forum!
configuring hp6500 for airprint
how do i air print from my hp6500?
how to enable airprint for hp 6500 printer
hp 6520 wont print sfter 15 minutes
hp printer won't print from ipad
hp6500 won't airprint
iphone wont print to hp 6500 anymore
setup hp 6500 airprint
