My iPad Speaker suddenly has gone very low in volume...Can Anyone help?
Discussion in 'New Member Introductions - Site Assistance' started by nnmathur, Oct 29, 2013.
  1. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    19,729
    12,628
    Welcome to iPad Forums!
    The member above had problems with sound because the iPad had been connected to bluetooth speakers. If you wish to use the iPad Pro with it's built in speakers, you don't have to disable Bluetooth, and the Apple Pencil will not quit working.
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    21,139
    7,362
    As an alternative to turning off Bluetooth on the iPad, you can always turn off the bluetootth speakers instead. Unless you've got some kind of multi-source bluetooth speakers than need to be on all the time, that's usually the best choice.
    Hold in mind the orginial question was from 2013. Things have changed a bit. These days it should be possible to pull up the Control Panel, choose AirPlay, and switch between the local speakers and other connected bluetooth or networked speakers. I can on my iPhone anyway. I don't have any bluetooth speakers paired with the iPad Pro to test.
  3. Zisha Greenberg
    Zisha Greenberg
    Jan 10, 2017
    I have the same problem end I don't have bleuthoot enabled on mi device I've tried to change every single setting nothing helped me
  4. J. A.
    J. A.
    Staff Member
    Nov 11, 2012
    19,729
    12,628
    Welcome to iPadForums!
    If this is caused by a setting, reset all settings. Go to Settings - General - Reset, and select "Reset all Settings". See if that helps getting back the sound.
    This reset will set back your settings to default, so everything you've changed before, will be back to it's original setting. This includes Wi-Fi, e.g. You'll have to go through the Settings app afterwards, to get back your preferences.
  5. jamesdave
    jamesdave
    Jan 25, 2018
    there is an app named "speaker clean", it might be helpful :)
  6. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    28,825
    10,918
    That’s an Android app and isn’t available for iOS devices.
  7. Brian 244
    Brian 244
    Oct 20, 2014
    477
    574
    Not to mention most likely useless.
  8. scifan57
    scifan57
    Staff Member
    Dec 3, 2011
    28,825
    10,918
    Apps like this are designed to eject foreign matter such as water or dust from the speaker. They are useless if the problem is not physical blockage of the speaker.
ipad low volume
ipad sound low
ipad sound too low
ipad volume low
ipad volume too low
low volume on ipad
my ipad volume is too low
volume low on ipad
volume on ipad too low
why is my ipad volume so low
