Mute and a little lock icon with a arrow circle
Discussion in 'iPad Help' started by mikescott1976, Sep 27, 2011.
  1. mikescott1976
    mikescott1976
    Apr 26, 2011
    15
    some how I muted the clicking on the key board? Anyone know how to get it back?
    Also, there is a lock icon with a circle arrow around it by the battery %. Was never there before. I have shut down the iPad completely and turned it back on and did not help.
    Any help?
  2. Jeeper
    Jeeper
    Nov 14, 2010
    436
    8
    Keyboard sounds can be found in Settings > General > Sounds.
    The icon you describe is for rotation lock. It is set either by the switch on the side, or by double clicking the home button and sliding to the left (depending on how you have "rotation lock" set up in Settings > General).
  3. giradman
    giradman
    iPad Wizard
    Apr 26, 2011
    7,014
    6,301
    Agree w/ Jeeper - the on-off switch in the right upper side of the iPad is defaulted as the sound mute switch - please be sure that this is not muted; this switch can be reset in the settings menu to control and fixate the screen orientation. As also suggested by double-tapping the home button, the lower taskbar will open, move to the left end and make sure that the sound is not muted. Finally, and you may have already performed this maneuver, reset your iPad - directions HERE - good luck and report back to this thread if your are still having a problem - :)
  4. mikescott1976
    mikescott1976
    Apr 26, 2011
    15
    Thanks guys, everything sightseer has worked. Thanks again!
a lock with a circle arrow ipad
ipad lock arrow icon
ipad lock circle arrow
ipad lock symbol with arrow
ipad lock with arrow around it
little lock with a circle around it ipad mini
lock w circle around it on ipad mini
lock with arrow on ipad
what is lock with arrow on ipad
what is the symbol of a lock with a circle arrow ipad
