Monitor WIFI usage for hotspot only
smaxell
maine
Is there an app to monitor wifi usage that will only monitor for a specific wifi connection? I have searched several and downloaded a couple at cost and they don't seem to be able to separate one network from another. I have a wifi hotspot with a 2gb data plan that I want to track usage on, but have no need to track wifi usage on my home network. I just want to monitor when I am connected to my hotspot.
TIA
scifan57
Regina,Canada
I don't know if this is what you mean or not,but I can monitor the data usage of the personal hotspot created by my iPhone. To access it I go to Settings>General>Usage>Cellular usage. This is part of the resulting screen.
image-671009443.jpgas you can see,the tether data shows how much data has been sent and received.
The same would apply to the personal hotspot created by an iPad.
S
smaxell
maine
That is the general idea, but I need something to keep a running total just for the hotspot for the month.
scifan57
Regina,Canada
That's what the tether data does. Tether data is the data sent and received by the wifi hotspot since the last time it was reset. You can touch the reset statistics button at the bottom of the screen at the beginning of each month to start a new running total for each month.
HeidiLehmanan
USA
i dont think there is an such think for monitring the wifi activity but one thing you can do is to check your wifi router it has logs in it!
scifan57
Regina,Canada
Check the second post in this thread and look at the screenshot from my phone.
S
smaxell
maine
I will have to connect to the hotspot again and see if I see that. I looked for that once and didn't see the tether or cellular usage part.
scifan57
Regina,Canada
The cellular usage section is at the bottom of the usage page in settings. Touch cellular usage and you will go to the cellular usage page. The tether data is there,just as in my screenshot,provided the personal hotspot feature is activated by your cellular service provider.
P.S. You look for the tether data on the device that is creating the wifi hotspot.
S
smaxell
maine
Yes it does have logs, I just wanted an easier way
Bingoldsby
Oregon
Smaxwell,
You don't say what kind of "Hotspot" you are referring to, so the responses seem to preclude that it is an iPhone. How about telling us what the hotspot actually is, and you might get some different answers.
As far as me knowing about apps that can keep track of data flow between specific devices.... well, sorry, can't help there. Good luck.
S
smaxell
maine
Bingoldsby said:
Smaxwell,
I have a wifi only iPad, so I bought a wireless 4g Samsung hotspot from my cell provider.
scifan57
Regina,Canada
I'm afraid that in this case you may have to contact Samsung to ask about monitoring the wifi usage of your hotspot. My answers presumed you were using the personal hotspot feature on an iPhone. What does the user guide for your portable hotspot have to say about the monitoring of your wifi usage?
S
smaxell
maine
You can check it in the settings, but I was more looking for an app that would reset automatically at the end of the billing cycle, etc. it would be much easier to just check an app as opposed to logging in to the settings on the hotspot remotely.
