Mobile terminal help
BornAfflicted
Bothell, WA
I can clear this up as I went through this last night Here is the fix. The link is an article written for the iPhone on 4.3.1, but it worked like a charm for the iPad 2 running 4.3.3.
DaveS
Washington, DC
Hi,
I noticed the app exiting behavior. You can use issh and login to the IPv4 loopback
Address as root as an alternative to get a local shell,
Regards,
Dave S.
PS - you also have to load the openssh package from Cydia after JB and before doing the above.
127.0.0.1 is the IPv4 local loopback address.
biobunny
Or you could always use SSH to connect and do the geeky stuff.
Sent From my jailbroken interestingcompanionPad using iPF!
J
johnl316
Langhorne, Pa.
Thanks graywolf your Link to the repository worked.
Bunny-if you tap on the link and then scroll down you will see the URL for the repository that you need to add to the sources tab in cydia.
After cydia adds the source scroll down and choose mobile terminal. It is then the same as installing any other app in cydia
