Maximum Data Transfer Rate between iPad 3 and PC with USB 3.0 ?
iPad3Questions
USA
Hello,
I'm having difficulty determining whether the iPad 3 transfers data between a computer at USB 3.0 speeds when connected to a USB 3.0 port. I'm assuming that since the answer is so difficult to find, it must be transferring it at USB 2.0 speeds regardless of whether it's connected to a USB 3.0 port, otherwise they would be marketing the faster data transfer speeds.
So, what is the Maximum Data Transfer Rate between the iPad 3 and a computer with USB 3.0 ?
Thank you.
AQ_OC
SC
iPad3Questions said:
Hello,
Thank you.
USB 2.0 speeds. No one really knows the actual speed of the link.
Michellelouis
Itunes application provided by Appleis the best way t o transfer data from iOS device to PC and todownload thelatest version of itunes application you need to visithttp://www.apple.com/itunes/
Butin rare situations if you are not able to transfer iPsd adat usingitunes application than you need a third party tool to transfer iPaddata.
formore information, visit at How to transfer iPad Data | iPad Data Transfer
Bosvaark
Cape Town
Hello,
Thank you.
Transfer rates will vary as this is also dependent on Computer CPU and hard drive access rates,
