Largest SD card used with a Camera Connection Kit
Discussion in 'iPad Help' started by davies375, May 25, 2011.
  1. davies375
    davies375
    May 18, 2011
    20
    So I intend to load movies onto SD card and use via the CCK but I was wondering what the largest card that people have used on here are?
    Im looking to buy a large SD card and wanted to know what the biggest was.
    Cheers,
    Davies
  2. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,921
    6,962
    32Gb is the largest card, by spec, that you can use.
  3. Kin Lau
    Kin Lau
    Apr 26, 2011
    45
    I've used 32gb cards.
  4. ThePhotog
    ThePhotog
    Feb 1, 2011
    213
    What class memory is required to transfer data at proper speed?
  5. twerppoet
    iPad Legend II
    Jan 8, 2011
    20,921
    6,962
    Shouldn't matter, as long as you aren't using some ancient 1st generation SD card. The iPad's connector isn't high end camera fast, so super fast SD cards would probably just be a waste of money, unless you're using a super fast high end camera, of course. :)
  6. davies375
    davies375
    May 18, 2011
    20
    Thanks everyone!
    32gb sounds good to me!
ipad 3 camera connection kit sd card size limit
ipad 3 camera connection kit size limitation sd card
ipad camera connection kit maximum sd card
ipad camera connection limit
ipad maximum sd card size
length sd card apple camera connection kit
max sd card ipad
maximum size sd card for ipad
what is the biggest sd card i can use in an ipad camera connection kit
what is the maximum size of sd card that ipad recognizes
