The next time this happens, tap and hold the bottom right key with the picture of a keyboard on it. Slide your finger to the dock button in the pop up that appears. Your keyboard should move back to the bottom of the screen.On my mini iPad, the key pad has started to move halfway up the screen when I want to type. Very annoying as it often obliterates the information I need.
I can't find a way to move it back.
Any ideas? Thanks!
Lynn
You're welcome, I'm glad I could be of help to you.Thanks so much scifan! It worked like a charm. Very grateful!
