Keep Losing WiFi
Discussion in 'iPad Help' started by Sexybum13, Sep 23, 2011.
  1. Sexybum13
    Sexybum13
    Aug 31, 2011
    5
    Hi, I'm still new at the iPad thing. But my iPad keeps losing wifi connection. I have to turn off wifi in settings and then turn it back on. This is really frustrating especially when doing stuff like THIS. I have had to type this twice. Just wondered if anyone could help me out with this problem. THANKS.
  2. johnhyunyoon
    johnhyunyoon
    Sep 15, 2011
    62
    I would make sure its not a problem with the wifi source itself first. If it isnt, I would try backing up and restoring the iPad to factory settings. If THAT doesnt work, I would make an appointment at the apple genius bar and have it looked at and possibly replaced.
  3. richsadams
    richsadams
    iPad Super Guru
    Mar 23, 2011
    3,500
    99
    Although you should make sure your network is functioning properly, you shouldn't have to restore your iPad.
    The most recommended "fix" for this issue is to go into your WiFi settings, tap on the network you're using (small arrow inside the little blue circle next to the network name) and tap "Forget this Network". Restart your iPad by holding down the power switch (outside edge) until the red power off slider appears, shut it down and then hold down the power switch again until the Apple logo appears. Once booted up go back into the WiFi settings and set up the network again.
    More here:
    iOS: Troubleshooting Wi-Fi networks and connections
    Hope that helps and let us know how it goes!
  4. jmbarker
    jmbarker
    May 12, 2011
    179
    I had the same problem with my iPad 2 and my iPhone. Turned out to be my router in my case. Apple Airport Extreme. Apple replaced it and have not had the problem since. I would check everything related to your home network to include the router, modem and any switches (if you have any).
  5. richsadams
    richsadams
    iPad Super Guru
    Mar 23, 2011
    3,500
    99
    Rebooting the network can often help as well...including the modem/router, etc.
i keep losing wifi on my ipad
i pad keeps losing wi fi
ipad 2 keeps losing wifi connection
ipad air keeps losing wifi connection
ipad keeps losing wifi
keep losing wifi on ipad
my ipad keeps losing wifi connection
my wifi on ipad keeps going in and out
why does ipad keep losing wifi connection
why does my ipad keep losing wifi
