Itunes problem
KevinJS
Edmonton AB Canada
Sorry if I'm missing something here, but iTunes is not your music player. It's your access point to the iTunes Store. To play music you need to use the Music app.
scifan57
Regina,Canada
angel4avon said:
Itunes wont play purchased music on ipad 2.. Any fixes?
This is what the music app looks like on the home screen.
jolie11
Well, you could use iPod (it’s orange with an iPod-like symbol on it) to play the music. When you click it you get a list of all music on your iPad. As soon as you tip on one of them playback should start.
At the bottom you can chose how to display your library (by Artist, Album, Songs, …)
You'll need this guide: http://manuals.info.apple.com/en_US/ipad_2_user_guide.pdf
dhewson777
Brisbane, Australia
Per Scifan above, the app is now called Music.
angel4avon
angel4avon
I have that app loaded and some songs play. I am not seeing any pattern. some play, some dont. Seems like it worked ok before the os 6 update. Is there any way to uninstall the app and reinstall? I have looked everywhere.
scifan57
Regina,Canada
The music app is a native app and cannot be uninstalled. Have you tried deleting the songs that don't play, then reinstall them?
giradman
North Carolina
Hi Angel4avon - welcome to the forum! :)
Before doing 'anything' drastic, the steps below are the ones I usually use initially when an app(s) is misbehaving - let us know if these maneuvers help or post back here for further advice - good luck!
When an app (or several) or misbehaving, I usually go through the following steps:
1. Force Close - open the multi-tasking bar (double tap the 'home buttom' or use multi-gesturing and swipe up); press & hold an app until all begin to 'jiggle'; find the offending app(s) and press the 'red circle w/ minus sign' - return to the home screen & try again.
2. Restart - press & hold the 'Sleep/Awake' (a.k.a. power) button until a red slider appears (may take a few seconds) - move the slider to turn off the iPad; then press & hold the same button until the Apple logo appears - wait for a restart.
3. Reset - press & hold the 'Power' and 'Home' buttons simultaneously until the Apple logo appears - this may take a longer time, so have patience; the iPad will 're-boot' - NOTE that none of these maneuvers will alter your apps, files, or settings.
dhewson777
Brisbane, Australia
The Music app itself is part of the iOS itself. I cannot be uninstalled or reinstalled separately. Try All of Giradman's tips first.
Are the "purchased" apps bought from the iTunes Store?
angel4avon
angel4avon
It did not work. Yes, all music was purchased from iTunes Store. I just installed iTunes on my net book and it said I was authorized on 2 computers. I also have it on my desktop computer. Could it be that this ipad is not authorized for my account?
dhewson777
Brisbane, Australia
If you're using the same AppleID for purchasing the music, it should be fine I would think. Does your music (or your iPad itself) get backed up to your PC ever?
Might pay to back it up, and then restore your iPad from the back up after doing an Erase All Content and Settings from the Settings -> General menu.
