iTunes: How to change sync settings without connecting device?
Discussion in 'iPad General Discussions' started by xlar54, Aug 15, 2010.
  1. xlar54
    xlar54
    Aug 5, 2010
    13
    I need to stop itunes from syncing my contacts. But to do this, I need to edit the sync settings before i plug the device in. But those settings arent available until after youve plugged the device in.. chicken, meet egg. Any ideas on how to do this?
  2. King Hal
    King Hal
    Jun 6, 2010
    401
    I suggest you load up iTunes, connect your device, and then immediately swipe the screen when it comes up with message "swipe to cancel sync" (not sure if that's the precise wording). Bingo, you can change your settings and then manually sync.
  3. Roi
    Roi
    Aug 9, 2010
    29
    I remember that the Application preferences of iTunes(CMD+,) has got a panel to configure the devices, including an option to choose whether or not sync automatically when the devices connect.
    But this was on a Mac, not sure if the PC version works the same way.
  4. michali
    michali
    Jun 4, 2010
    353
    18
    Yes, PC works the same way.
  5. rayw
    rayw
    Jun 18, 2012
    Hi Guys,
    My first post and the reason I came here in the first place.
    I found the answer:
    Open I tunes after it recognizes your device (iPad, iPhone) click on it's name. And then click on info at the top of the right hand panel. There you will see at the top SYNC OUTLOOK and other options down the page, just UN-click the ones you don't want.
    Regards, Ray
change media sync options on ipad
change sync settings in itunes
edit ipad settings without it connected
how do i change my media sync options on my ipad
how do i change my sync settings on my ipad
how to change media sync options on ipad
how to change sync settings on ipad
how to find the sync setting on your ipad
ipad sync settings
itunes phone
