iTunes could not connect with iPad unrecognised device
Discussion in 'iPad 2 Forum' started by Inverbertie, May 3, 2013.
  1. Inverbertie
    Inverbertie
    May 3, 2013
    6
    Help please!!!!
    I have spent over 8 hours reloading drivers, turning pc and iPad on and off, uninstalling iTunes then reloading and I still caws not get iTunes to recognise my iPad 2.
    Everything worked fine until I upgraded to windows 8, then went back to windows 7 - since then iTunes will not pick up iPad. (no issues with iTunes picking up iPhone or iPod, just iPad 2.
    Any suggestions please on how to best to resolve?
  2. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    Can you see the iPad in Windows Explorer?
    Just trying to see whether this is definitely an iTunes issue.
    I assume you have tried different USB ports and cables.
  3. Inverbertie
    Inverbertie
    May 3, 2013
    6
    Yeah, iPad comes up in explorer. I have tried using 3 x different cables, different ports to no avail. It really has me stumped.
  4. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    Do you have an installer for an older version of iTunes? It might help to roll it back.
  5. Inverbertie
    Inverbertie
    May 3, 2013
    6
    Kevin, yeah installed it back to version 10 - iTunes picked up previous library etc, but just won't recognise the device? Do you know of any other way/software that can be used instead of iTunes to put music, movies books etc from pc onto ipad?
  6. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    I don't because I can usually get iTunes to work, eventually. There are ways, however. Maybe wouldn't hurt to start a thread where we can discuss iTunes replacements. I'm sure that would get you some answers. As far as I know there's no recent thread running that's similar, so it's good to get one going.
    It would still be good to solve your existing problem, though.
  7. Inverbertie
    Inverbertie
    May 3, 2013
    6
    Thanks for trying. I think the new thread is a good idea
  8. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    With luck it will concentrate any and all info on the subject in the same place. I know some people simply hate iTunes. I'm not one of them. I just like things to work, but nothing wrong with having multiple solutions.
  9. Inverbertie
    Inverbertie
    May 3, 2013
    6
    Hey Kevin, thought id let you know I finally resolved the issue. Regrettably i had to do a complete system reset - this cleared the issue, now being picked up by Itunes. Thanks for all your help and assistance.
  10. KevinJS
    KevinJS
    Staff Member
    Aug 6, 2011
    10,650
    1,418
    No problem. I'm not a fan of System Restore because it means that you don't get to figure out exactly what went wrong, but at least you got things moving again.
    Sent from my stock iPad 2
apple unrecognised ipad
ipad unrecognised device
itunes could not connect to this ipad
itunes will not launch when ipad is connected to windows 8
windows unrecognised ipad
